In the German database, upon receipt of goods, the receptionist must enter the goods received in the Warehouse Module / Put-Away.
For an article (which already exists in the stock) is received, the system provides a default location (TX) while the stock of products (same product / reference) already received, is found somewhere else, for example the location Bin 8. I am wondering why the system always offers the same site (TX), whether there is already or not the item in stock. I would like to know if it is possible that the column Bin Code affects the value of the actual location of the item already in stock (eg 8).
any idea why i am getting this plz?
What do you mean by this? Stock is valued by location (warehouse) if you have set this up in an average costed environment, otherwise it is by all warehouses.
In the bin contents you can define if it is fixed or default, been a long time but I guess it is there that is driving your default bin selection, and then the putaway reflects where it actually resides.
Just Try to check Default Loction on Item/SKU Card. If you are using Bin Granuals you need to check Default Bin in Bin containt Table for a particular Item.
Hope it will help you.
Vijay Mishra
Thanks guys,
Will have a look and get back to you.
