Hi I have been playing around with User Portal 2.60.D and Commerce Portal 2.65 and I noticed that the startup trigger that seems to be executed by the User Portal Application Server 2.60.D is the one with ID 98 form the coduenit 1, whereas the trigger executed by the Navision Application Server 2.65 is the one with ID 99 from the same codeunit. Also, in Commerce Portal they use some kind of timer control —similar to the OnTimer that was used in the WebShop— that is not used in User Portal. Has anyone developed using these triggers? Toni
No, developement starts in CU6702 not in CU1. BTW: Are you sure you are “End User - Beginner”? Your question is far beyond the stage of a Beginner ------- With best regards from Switzerland Marcus Fabian
