Hello,
I am attempting to setup the system to track production variances caused by standard costing. I have seen several ways to do this, but curious the best.
The situation: Every item, work center, and BOM will have a standard cost applied to all sites. All production orders will need to be costed with these standard costs. The actual production will not use the same costs as the standard. (The standard cost might include .05 overhead and .20 labor, while the production would be .07 and .17 (leading to a price variance of .02 and .03)). I need to track these variance separately.
Where it stands: I know I can track the variances so long as the actual production cost of a BOM has a calculated standard cost to compare to. I know I can track the separate costs using the profile and specifying posting accounts based on the cost group.
Issues: I can accomplish this by having two routes/versions that build a BOM; one with “Standard” cost categories, the other with “Production” cost categories. Activate the price with standard, produce with the other. OR I can use the fallback. Have two versions, one with all standard costs in it (item, boms, cost categories), the other set to fallback to the standard and only house the production cost categories. When producing it grabs the standard BOM, calculated at the standard version, but actually uses the production cost categories, leading to the variance.
Which is best, or is there a better idea that has escaped me? Thanks in advance. The real issue is to capture the variance by cost group/categories, and that the real productions costs are known, not some hap stance from over/under consumption or RAF. We know the labor cost is higher/lower than the standard we want to cost at, we still want that variance.
