Standard Cost Worksheet error - uncertified BOMs
Hi folks,
We will always have some uncertified BOMs and Routings as products are developed as engineer to order.
However, we’ve hit an issue where the Standard Cost Worksheet. when I click on Roll up Standard Cost I get an error:
Status must be equal to ‘Certified’ in Production BOM Header
Can anyone please point me to a workaround for this? Is there any way to filter out items which have uncertified BOMs?
Cheers,
Hamish
When you’re doing your Cost Rollup, do you have sub-assemblies in BOMs that are uncertified? This can happen if the parent Item is Certified, but someone moves a sub-assembly into Under Development.
Hamish - in your ETO environment you may be able to ‘block’ the item and run planning filtering only for items not-blocked?
You would block the parent and all associated low-level prod items to insure you are not getting partial roll-up results creating potential inaccurate revalue entries.
Best Regards
John Grant
Innovia Consulting
Potentially, however I think this is also affecting items which are still in development - top level BOMs and Routings. It’s blocking me from rolling up costs for all items as a result…
That’s a good potential solution John, thanks. I can block those items until they’ve been reviewed and approved. I’ll try that today. Cheers
Following up this issue - John, you were correct. Blocking the items which are still redevelopment allows the standard cost worksheet to operate as expected.
Thanks for your help John and Ben :slight_smile:
