When a new user is created, setting its user groups to default user groups other than Admin.
An error message appears upon login “Stack trace: The company dat does not exist. (S)\Classes\Application\logUpdate – line 12 (S)\Classes\URecord\Update”
And I can’t able to save my customer feedback option.
In \Classes\Application\logUpdate, line 12 there I believe is "changecompany(‘dat’).
Anybody happens to have encountered this before? Appreciate it if you can share how you have solved this.
Yes there is other company in my database, I believe it does have an access because same user group in another server/environment the error does not appear, I have just imported the user group in the new environment.
Hi Everyone, found out that a database log for User information update is setup with DAT as domain is used. As this is turned off, seems the error message does not occur anymore.
