SSRS report time out error and performance issue for customer account statement
Could you please give me any idea about how to solve this issue?
When i run the report in the path Account receivable → Report → External → Customer account statement. it take nearly 40 minutes and come with the below error.
A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
Thanks and Regards,
Manikkam.R
This is a known issue…
try out this…
http://sinedax.blogspot.in/2012/11/ssrs-report-ax-2012-operation-has-timed.html
here we may need to make some changes in code the loop which it is checking may be long and taking lot of time
my best bet try to make some changes in code or else
set the time out property for the report to max
http://technet.microsoft.com/en-us/library/ms155782.aspx
http://blogs.msdn.com/cfs-filesystemfile.ashx/__key/communityserver-blogs-components-weblogfiles/00-00-01-37-69-metablogapi/6114.clip_5F00_image002_5F00_1F725A53.jpg
