SSRS Report, Output PDF
I have created a Report Data Provider (DP), but when I try to open this report, if the report has a large amount of data, it will give me an output PDF instead of the usual SSRS viewer. However, if there is only a small amount of data, it gives me the SSRS viewer as usual.
Which version is it about? You attached tags for both AX 2012 and F&O.
The version is D365 F&O
Yeah, I have the same problem. I don’t know why
