Hi how do get to print report header on each page…
thanks in advance
thanks in advance
Tablix properties was changed for the table. as above still it is not showing on my 7 pages report
Right-click the design surface of a precision design and choose Add Page Header. Controls in page header are repeated on each page.
But Mr drab i tried it refer screen shot.
I would have known it if you said it before. You’ll save your time and time of everybody else if you provide more detailed description of your problem.
Do you have any controls in your page header? Please try to add a static text there; maybe your controls are there but they don’t have any values or their Hidden property is set to False.
i have a table in report body whose header tabs i am trying to print as it is 8 pages report.
Aha, so even your original question was wrong. You don’t want “to print report header on each page”, you probably want to repeat tablix column headers on each page.
Unfortunately I don’t have any information about what you did (e.g. whether you have any static group to repeat), so I can only show you the documentation: Controlling Row and Column Headings.
You have to enable “Repeat Header rows on each page” on the table properties form for seeing the table header on all pages.
Try to do the following,
Raghav.
thanks martin,anand and raghav
raghav i have to tell u that there isn’t any grouping in my table
Thanks all … raghav it is working now i explored it fully [:D]
