Can anyone explain how you declare a parameter in a class as an array of values to be selected from in a where clause.
My class query wants to select where AccountNum in (‘C0001’,‘C0005’,‘C0012’). These are the account numbers selected from the drop down multi select on the SSRS report.
So I would expect the code in my class to be as follows:-
select * from custTransTotalSales
where custTransTotalSales.AccountNum in contract.parmAccountNum()
So I need the correct syntax for the above statement and the declaration for contract.parmAccountNum()
