Hello everyone,
We have several reports that were done by an external team, and right now, multiple reports have similar pattern of error when using Visual studio, as follows. I am pretty sure that the visual studio is using the correct configuration, as I modified the visual studio 2010 shortcut using /AXConfig parameter, like these pages say https://msdn.microsoft.com/en-us/library/gg889291.aspx
Any advice greatly appreciated.
Error 1 Unable to connect to the AOS specified in the AX Client Configuration. The configuration could be missing, invalid, or the AOS is not running. To connect to the AOS, check the network connection between the client and the AOS, verify that a valid configuration exists, and that the AOS service is running on the server. C:\Program Files (x86)\MSBuild\Microsoft\DynamicsTools\Microsoft.Dynamics.Framework.Design.Reporting.Modeling.targets 103 6 ReportModel5
Error 2 The “GenerateRdlTask” task failed unexpectedly.
Microsoft.Dynamics.Framework.BusinessConnector.Session.Exceptions.NoKernelSessionException: Unable to connect to the AOS specified in the AX Client Configuration. The configuration could be missing, invalid, or the AOS is not running. To connect to the AOS, check the network connection between the client and the AOS, verify that a valid configuration exists, and that the AOS service is running on the server. —> Microsoft.VisualStudio.Modeling.ModelingException: Unable to connect to the AOS specified in the AX Client Configuration. The configuration could be missing, invalid, or the AOS is not running. To connect to the AOS, check the network connection between the client and the AOS, verify that a valid configuration exists, and that the AOS service is running on the server. —> Microsoft.Dynamics.Framework.BusinessConnector.Session.Exceptions.NoKernelSessionException: No .NET Business Connector session could be found.
at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsAdapter.GetObject(String objectName)
at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsAdapter.Microsoft.Dynamics.Framework.BusinessConnector.Adapter.IAxaptaAdapter.GetObject(String objectName)
at Microsoft.Dynamics.Framework.BusinessConnector.Proxy.ProxyObjectBase…ctor(IAxaptaAdapter axaptaAdapter, ProxyClassName className)
at Microsoft.Dynamics.Framework.BusinessConnector.OperationExecuter.HandleError(IAxaptaAdapter adapter, Exception businessConnectorException, Collection`1 messages)
at Microsoft.Dynamics.Framework.BusinessConnector.OperationExecuter.Execute[T](Collection1 messages, Func
1 nodeAction)
at Microsoft.Dynamics.Framework.Design.Modeling.Interop.TreeNodeOperationExecuter.Execute[T](ITaskLogger logger, Func`1 nodeAction)
— End of inner exception stack trace —
at Microsoft.Dynamics.Framework.Design.Modeling.Interop.TreeNodeOperationExecuter.Execute(ITaskLogger logger, Action nodeAction)
at Microsoft.Dynamics.Framework.Deployment.Reports.GenerateRdlTask.SaveReport(ReportDefinition report, TreeNode reportNode, ReportAdapter reportAdapter, Dictionary`2 designRdlMap)
at Microsoft.Dynamics.Framework.Deployment.Reports.GenerateRdlTask.Execute()
at Microsoft.Build.BackEnd.TaskExecutionHost.Microsoft.Build.BackEnd.ITaskExecutionHost.Execute()
at Microsoft.Build.BackEnd.TaskBuilder.d__20.MoveNext() C:\Program Files (x86)\MSBuild\Microsoft\DynamicsTools\Microsoft.Dynamics.Framework.Design.Reporting.Modeling.targets 103 6 ReportModel5
Thank you,
Kwen
