ssas project in ax 2012
how to create ssas report in ax 2012 using cubes? plz suggest any example
thanx
SSAS only provides data, you have to use something else to create reports, e.g. SSRS or Excel. Create a report by using SQL Server Report Builder to connect to a cube describes one of possible ways.
You can try it through Power View Tool.
Create a report by using Power View to connect to a cube
You can also do it in AOT. Example is given the below link.
Creating An Analysis Services Cube For Dynamics AX 2012 in AOT
