I am working on a control charting application for a chemistry lab and need to run a “Square Root” calculation. Is there any way in Navision to do this? We are running version CA 2.60.B. I know I can export the required data to Excel but this is a real pain when I only want to do some calculations and print a report. Any help on this would be most appreciated.
We have the POWER function in Navision. POWER(2,0.5) calculates the square root of 2. Hope this helps…
If you search the Navision help file with the word “sqaure” you’ll find the power command with documentation and examples.
Thanks, thought this command was only for the reverse. Really appreciate your help.
