Hi Navision,
I can not able to access to the dynamics NAV , though my database pops up in the Database name I cant able to connect to navision. My SERVER is in client computer that I installed the Sql server 2008 in that single computer. So My question is can I able to connect to my compute which is both as client and server ? If tried to connect to with windows authentication it displays a message of …The extended stored procedure xp_ndo_enumusergroups in the library file xp_ndo.dll, is not available on the server…
I can not either login with the sql server login Id…
I appreciate for any help
