Hi… Would like to find out whether is it possible to install Navision SQL database in one server and install the Navision application in another server? Please advise Thank you. Regards, Catherine
The application is part of the database data. It is not an entity that can be separated from the user data.
Originally posted by ngps - 2004 Oct 27 : 10:39:13
It cannot be done, since Navision does not work like IIS and SQL ! The db and the application are interdependant of one another. All you can do, performance wise, as far as the db and application are concerned is to split the db physical file up to 16 distinct hard drives. [;)]
