You say that you can send mail on port 465 to everyone. What is then your problem using this port?
I’m not familiar with Yahoo BizMail, but I’m also using SMTP to send here on the site, just from Microsoft.
And here I had to create a setup allowing which servers/IP’s were allowed to use the SMTP connection from.
Could you have an issue there?
But RWN should be correct. Generally port 465 have been deprecated since 1998 in SMTP connections. 587 “should” be the correct port for secure SMTP.
Just to be sure - your setup is the SAME in both versions? You try to test it on the SAME computer?, and two different NAV version without changed SMTP code?.
And yet works in NAV 2018 but not in NAV 2017??
Sorry I am going to repeat myself. The code is the same in both versions. So it should not be a problem at all. I have myself never experienced this problem.
