I have a working XmlPort that imports a CSV file into a custom table. At the moment it’s called manually via a Page Action. A dialog appears and the user selects the file to be imported and clicks OK. Now, we want to remove the human intervention, drop the CSV file into a folder and call the XmlPort from a Job Queue. Presumably, the aforementioned folder will need to be cloud storage (Google Drive, Dropbox, OneDrive etc…) as SaaS doesn’t have access to a local filesystem? How can this be done using AL?
Hi @NickOak365,
There are many approaches to do this…
- FTP: Dynamics 365 Business Central: handling files via FTP on SaaS – Stefano Demiliani, FTP with Business Central SAAS Azure Blob Storage, How to read files via SFTP in Business Central - Ivan Singleton.
- Onedrive: Business Central and OneDrive for Business Integration - Business Central | Microsoft Learn
- Local file system (yes, this is possible): How to create a Windows Service and connect it with Business Central to manage Local files - Ivan Singleton
- Etc…
Thanks for your response. I’ve started investigating and it looks like all of the suggestions above involve spending money: Azure Storage Account, OneDrive Premium etc… in order to get started. I need to prove concept and demonstrate internally before any money gets spent. Is there a method that can be done using a free 30-day evaluation?
If you can mount an FTP on a server, you can try this: Dynavision Connect
I don’t know how it works and how much it will cost after free trial period.
