Showing employee name in report dialog
Hi,i have 2 fields in report dialog.EmpId and Name.i have drop downs for this.If i select one empid ,the name of the correspondig id should be populate in name field.can any one help me please.hint is use of join in contract or ui builder class.
Hi sunitha, welcome to Dynamics User Group. Please make sure that you asked in the right forum (I deleted your message from the Technical forum), that you used descriptive thread titles and you attach appropriate tags, especially your version of AX. The answer for AX 2012 is completely different than for older versions.
