Hi guys i want to request about something i create report in navision but when i filter this report in request filter field by posting date then write as example 12/02/12…13/03/13 my problem is how i show this format in report(from…to) in header of report
You need to use PostingDatefilter := “”.GETFILTER(“Posting Date”);
where PostingDatefilter is a Text type variable in OnPreReport trigger and use PostingDatefilter in sections
Hi mohanna i make as you told me
1- define globale variable as text 100 datatype and his name rangedate.
2-i define globale variable as record datatype and his name is PurchHead.
3- then i write
rangedate := PurchHead.GETFILTER(“Posting Date”);
in on pre report trigger and onpre section purchase.rcpt.header
but also not work why
and also date i filter to it as example 12-01-13…03-03-13 in posting date in purch.rcpt.header
No need to define record variable.
use the dataitem name in record place…
no need to write in onpre section trigger.
i mean to add the text variable in sections…
OK thanks mohanna
