I think I’ll never understand how navision does it work !!!
I explain you my problem :
I have 2 sales line in my order, i’d like to add a third sales line between them and when I validate the description field, I have to show the Line No. of the live above !
Example :
Step 1:
Line Type No. Description
10000 Item N001 D1
20000 Item N002 D2
Step 2: Insert a new line between the lines above
10000 Item N001 D1
15000 Item N003 D3 << When I validate “D3” I’d like to show message 10000 (Line No. of line above)
20000 Item N002 D2
I tried several alternatives, the problem is when I validate the description field, I have not yet the Line No. so I did my code in on insert record trigger of the page. (my code Below)
The problem with any of that is that it stops working once the user sorts the form differently. I think what needs to happen is if the related line is created by some function, the function should populate that line. You could add a little function to the Line button just to create the related line without any other fields populated. If it’s manual entry, I’d provide a lookup into the line table.
Yes it is a manual entry, How could you make a lookup on this field ? the probleme, when you have several rows for exampl
Line No. Type Attached to Line No.
10000 Item
20000 Item
30000 20000
35000 (I want to attach this line to Line No. 20000)
40000 Item
you can’t do lookup ! my solution is to find the first Item above the line that I want to attach … bu I don’t know how ??! (and the problem here I dont know the Line No. of created line when I do my treatment)
Sure you can, lookup into the sales line table where the document type and document number are equal. In the field’s table relationship property, put in something like:
“Sales Line”.“Line No.” WHERE (Document Type=FIELD(Document Type),Document No.=FIELD(Document No.))
