Hi, when I use a subform and try to use a shortcut to it in my menu-items sometimes it works other time it doesn’t. 1. I setup the mainform and use the wizard to put up all fields. 2. I setup the mainform and put the fields on myself. When I do it myself (2) shortcuts like F5 to the subform don’t work anymore. In both ways the properties are exact the same. Now I’m scared… and always use the wizard.
Mark
When you press F5, the system will automatically run the look-up form that is connected to the active table. So, you will have to check your table properties. Look at the propertie: ‘LookupFormID’. Here you can specify the (tabular type) form that shows up when you press F5.
