SHELL alternative in C/AL
Hi Guys,
I wish to execute an external program with 2 paramaters in the C/AL underneath a button on the Purchase Invoice page.
I see references to using SHELL, but when I compile the Error List tells me it’s obsolete for my version (which is NAV 2009 SP1.)
Am I missing something?
is it for RTC?
http://www.mibuso.com/forum/viewtopic.php?f=32&t=31440
It is for the RTC yes.
That post looks great but my problem as always is knowing what the C/AL Local Variable declarations should be, do you know what they are? i.e. for _commandLine etc … Sorry I have no experience of that, but learning!
i am not sure, this may be a TEXT datatype.
You can generally tell a data type by the value that is being assigned to it. If it assigned a set of upper and lower case characters, it is a Text variable. Upper case only, a Code variable. True or False, it’s a boolean. A number without decimals, an Integer. And so on.
