I have prepare a test company with all data: Tems; Vendors; Customers; GL accounts . Now I need to copy the same data to several other companies ( at least 15) , what is the best way to copy all those information in those companies without forgetting something???
All setup should be the same ( Sales setup ; Inventory setup ; Purchase setup ; finance; etc…) . I need a way to startup a company easily and rapidly.
I already done that for the first company and I need know to copy all of data that I have done to other companies ( Item; GL; UOM; Customers; Vendors ; tec… are the same in all companies.)
I dont want to do the same for the other 14 companies…I want to copy all data
Hi In fact what happen is : When I create a company I have to select the company type . Why? I do not want to use RIM at this stage because the company type does not exist in the list.
So I select one type : Wholesale and finally I can see all tables .
However when I copy Item table, I noticed that “Item Unit of measure” does not get populated so how can i solve that?
