Hi All
I want to rearange the feilds on the form, for that i select the feild right click /setup rearrange the field save and close when i second time open the form, it is not like i arrange it. Suggest me how can i solve this problem.
thanks
Hi All
thanks
After you done with your rearranging fields, and While saving, are you getting a dialog box “Save user setup” ??.
Once you a name for this modification, it will be saved and when you repon the AX also the modification remains.
i did the same but the same problem i am getting. And also i have to do it at user system, what i am doing is giving the admin right rearanging the field and taken back the admin right. and restart the AX.
thanks
dont give and take the admin rights .
let the user save the form with the current user rights and then you would be able to see the saved form.
thanks,
vikas Mehta
user does not have the setup rights.
