I Have been trying to set up a test system since two days. Here is what i did.
The Production system is using windows server 2003 & am setting up the test system in windows Server 2008.
I installed AOS,Application file in the server 2008 and then copied the application files from the folder C:\program Files\Microsoft Dynamic AX 2009\50\application\appl
And pasted it in the windows server 2008 same location C:\program Files\Microsoft Dynamic AX 2009\50\application\app.
Then i opened SQL server 2008 R2 server management studio and restored the Database of the production system
Started the AOS and tried to open AX client its showing error
Am getting the following ERROR
You don have the User rights to login in.
Please Suggest me what i can do to set up the test system
Ya i have access to the production system i installed the new AOS with database name AXDATABASE and i restored the production system data to this database
Restore the database to the AX Database mentioned during installation. Before restoring please make sure that the AOS is stopped
Open the SQL server management studio and select the AX Database and then goto the tables and look for DBO.USERINFO table
and then rightclick this table and goto edit top 200 rows and then look for the two field SID and NetworkDomain
Enter the Test System Domain name in Network Domain and then to enter the SID we have to first look for SID in regedit
Goto Windows>Run and type REGEDIT… Then in Hkey_USERS you will find something like this with your own SID for your system (S-1-5-21-190089466-2791162007-4016149680-1000) Copy this and paste it in the USERINFO table’s SID field.
