Dear Experts,
I have 20 unit machines with the same type and same capacity.
I want to set it in module resources.
Should i set the all 20 unit in the resources ?
So i will have 20 Resources in this module.
Thanks in advance
Regards
Rudy
Dear Experts,
Thanks in advance
Regards
Rudy
Hi rudy,
If you want to plan and set production order for each of these machines than, I think it’s better to set each machine an group them into a group.
Mauro
Do you need to plan for each machine would be my question.
Dear all,
All I want is if I set the each machine in resource with the same capacity for example 10 qty.
And when I create the production order for item FG with the quantity 100. So It will run 10 machines in production order.
The point is how many machines that will be run in the production
Thanks in advance
Regards
rudy
I think the sequence is fillup the fist machine than the second and so on (I suppose you’re working with finite capacity). The sequence depends on other elements such as if you have settent a priority per each machine.
Hope this help
Mauro
Dear Mauro,
So if i have 20 machines, i must register the 20 machines in the resource and group them in resource group. Is it ?
Thanks in advance
Regards
Rudy
Hi Rudy,
That’s what I have done.
Sorry for such a delay in answering
Regards
Mauro
