Hi Guys,
I am creating a table by using X++ code.I want to set the field properties . Please let me know how to set the field property by using x++.
Thanks in Advance…
Hi Guys,
Thanks in Advance…
TreeNode.AOSsetProperty() is what you need. Check out this example:
#Properties
TreeNode fieldNode = TreeNode::findNode(@"\Data Dictionary\Tables\Address\Fields\Name");
fieldNode.AOTsetProperty(#PropertyMandatory, enum2str(NoYes::Yes));
Thanks Martin…
Hi Martin,
Suppose i want to set the left property through code then how i will use ?
Reply with simple example
thanks in advance
#AOT
str myProp;
TreeNode treeMenuItem,treetable;
// set properties
treetable = TreeNode::findNode(@"\Data Dictionary\Tables\TestTAble\Fields\Building");
treetable.AOTsetProperties(“PROPERTIES\n Label #” + ‘Build’ + “\n ENDPROPERTIES \n”);
treetable.AOTsave();
myProp = treetable.AOTgetProperties();
info(myProp);
I don’t know which Left property are you talking about, but it should be quite clear from my code that property name is the first parameter of AOTsetProperty().
