Set Margin in Report Section
I want to set the Top Margin of the Report into 0.5’.
Since I already put the textbox into the top but still it has a default 1inch margin.
Does anyone know how to set it in hard code. Because when i set it in Blank Data Item Properties, it constantly change every time i print.
Please help me.
So you are saying whne you click on the blank line under the last dataitem, you view the properties.
there you see the margin options. you change them but they are reverting back everytime you run the report?
yes i view the properties from the blank data item and i change the value omitting <>.
when i print check using (8 x 11) bond paper and it print to my expected location, but when i use a bank check size it doesn’t print to my expected location of the check.
do you have any suggestion…
Ah, the dreded check report. You didn’t mention that in the first post. I’ve always found the check report to be quirky.
Best to work on a copy of this report. I remember trying to move an object down a line and making the section smaller seemed to be the obvious solution and what worked on all other reports. But I found I had to do the opposite to get what I needed.
The check report can be tricky and alot of trial & error. If the task becomes too much ask you Nav partner to deal with it for you.
