Set field to be mandatory on Card Page
Hey All,
Working with NAV 16
I’ve got a page action on a card page that creates a new customer record, essentially. It’s called ‘Create Client’
My goal is to make a certain field on this page, ‘Client Code’ mandatory.
I don’t need the field to be mandatory ALL the time, only when they call the creation process from this page action.
I tried to set field properties to accomplish my task:
ShowMandatory for Client Code = TRUE
But this doesn’t actually enforce that the user enter this code before closing the card page.
NotBlank for Client Code = YES
This didn’t work because it only prevents the user from closing the page with a blank client code IF it originally was filled in. In my situation now I need it to be enforced, where if a record will be saved from the action then a ‘Client Code’ must be entered.
Are there any properties that I missed?
The code for the page action:
Create Client - OnAction()
// create a new Client
Rob_CreateSubContact(2);
- OnAction()
CreateCustomer(ChooseCustomerTemplate);
- OnAction()
CreateVendor;
- OnAction()
CreateBankAccount;
New Work Order - OnAction()
IF VAR_CreditHold THEN
ERROR(‘Customer has credit hold. Cannot create work order.’);
// exit is customer is inactive
IF (Inactive) THEN
ERROR(TEXT_009);
IF (VAR_CustomerRec.GET(“No.”)) THEN
IF (CONFIRM(TEXT_010)) THEN
VAR_CustomerRec.CreateWorkOrder();
On the OnQueryClosepage trigger you can add a code to check if the field Client code is filled in.
Found the OnQueryClosePage trigger.
Should I perform the check using TESTFIELD?
You can use TESTFIELD or you can give your own error message using Error function.
used this on the trigger.
IF Client_code = ‘’
THEN
ERROR(‘Please insert a value into the Client code field’);
thanks !
Yes, this will work, when user tries to close the page and if Client code is blank then user will get this message.
1 I would perform this check in table-trigger OnModify. Recommended to do it via Events.
2 Property NotBlank does only work on fields that are part of primary-key.
3 Property ShowMandatory only informs the user, that the field should contain some value. It does not demand anything.
Otherwise: More correct syntax is using FIELDCAPTION:
ERROR(‘Please insert a value into the field “%1”.’, FIELDCAPTION(“Client Code”));
And to be perfect, use Textconstants :wink:
