Set a Filter with OR operator
Hi, How can I set a Filter on a Table in 2 different fields with OR operator ? i.e. (Owner=User1) OR (Developer=User2) where Owner,Developer are fields in a Table. Thanks in advance
Hi Philip, Short answer: You can’t. Long answer: You need to write some code which examines all records and MARKs those you want to show. Then use MARKEDONLY. There is no simple filter expression for this.
This question has been answered countless times before. A recent answer can be found (using the SEARCH facility [;)]) here: http://www.navision.net/forum/topic.asp?TOPIC_ID=9142
thats incredible, no OR functionality
quote:
quote:
Perhaps it is - compared to e.g. Oracle and MS SQL. But Navision’s filter does have other advantages - one I use a lot is to change the filter on the fly while beiing “inside” the search/select-statement. If you in Oracle starts a select-where-statement you are stuck in that where-statement. On the other hand - if you have a tool, learn to use the tool; with one tool you will do it one way, with another tool you will do it another way. If you are good, you’ll solve any problem, regardless of the tool. [;)]
