Services keep losing login credentials at restart
Hey guys,
We have Navision installed on a Windows 2008 server with SQL 2008 … things seem to be going well except for the fact that when we restart the server , these services :
  • Application Server for Microsoft Dynamics NAV Classic SERVER-SQL
and
  • Microsoft Dymanics Nav Server
lose their login credentials and cannot start… I would have to right click, go to properties, and even though the user is written, and the password field is full of black dots, i just re-enter the password and re-confirm it… click on OK and start , service starts!
This is very unacceptable as this is a live server and shouldn’t need so much human intervention… any ideas on how to resolve this issue?
Wassim
Go to properties of Service
Go to Recovery Tab
Select ‘Restart the service for every attempt’
This might resolve your problem.
I tried this manually (by right clicking on choosing restart), it just wouldn’t start (until I do above mentioned steps).
So the main problem is to have the service remember the password andnot lose it on reboot…
Is your service account added in NAV Database windows authentication?
Have you set the services to start automatically?
Have you checked the event viewer to see if there is some sort of error/message to help understand what is happening?
Hey guys,
the user is authorized and the service is set to run automatically… the password isbeing re-entered then the service runs… so this is not a permission issue ((the user is not being changed)
thanks again
Wassim
Did you check the Event viewer?
Maybe you want to check out this one and related “Walkthroughs”:
http://msdn.microsoft.com/en-us/library/dd355184.aspx
I am still waiting for a server restart to recreate the problem and know exactly when to go through the event viewer… with it being a live server, I try to minimize server reboot for maintenance and testing reasons… but once it restarts, event viewer it is (why didn’t I think of that before?)
It does not mention my problem … Navsion is already installed and running pretty well, I have many clients using it and using thejetreport plug in as well…
Ok So I recreated the problem the other day, below are the entries foundin the event log (server is in German)
Type Date and Time Source EventID
Warnung 01.12.2011 00:50:48 SQLISService100 274 (1)
Warnung 01.12.2011 00:50:57 Winlogon 6006 Keine
Warnung 01.12.2011 00:50:55 Winlogon 6005 Keine
Fehler 01.12.2011 00:51:34 Report Server Windows Service (MSSQLSERVER) 107 Verwaltung
Fehler 01.12.2011 00:51:36 Report Server Windows Service (MSSQLSERVER) 107 Verwaltung
Fehler 01.12.2011 00:51:58 Report Server Windows Service (MSSQLSERVER) 120 Aktivierung
Gets solved once I right click the server and just retype the password , it already has the login as clicked and username entered… you just need to retype the password… quite annoying
any ideas?
I think You have an issue with the right to log on as batch job is defined in the local policy which gets overwritten by the domain policy and the right gets removed.
