Navision version 2.6 We are currently experiencing the following error Event ID 7023 Description The Financials Server GVLIVE service terminated with the following error. Incorrect Function. We also get a Dr Watson error 87 application at the same time. This error is occuring approximately 2 to 3 times a week.
we found that reducing the length of the directory & file names of the database files removed this problem (i.e. use c:\DB\P1.fdb+d:\DB\P2.fdb+e:\DB\P3.fdb). It is as if there is a maximum length for the commandline when starting the server.
