Hi ,
When user click sales order from one of our client PC system hang , and this one will auto stop the service on the server . so far this PC has this issue .
Nav Version 2015 build(8.00.37874)
event log details follows, Any idea?
Log Name: Application
Source: MicrosoftDynamicsNavServer$DynamicsNAV80
Date: 5/9/2015 2:22:27 PM
Event ID: 216
Task Category: (13)
Level: Error
Keywords: Classic
User: N/A
Computer: DB8R7R42.lap-laser.local
Description:
Server instance: DynamicsNAV80
User:
Type: System.Runtime.CallbackException
Message: A user callback threw an exception. Check the exception stack and inner exception to determine the callback that failed.
StackTrace:
at System.ServiceModel.Channels.CommunicationObject.OnFaulted()
at System.ServiceModel.Channels.CommunicationObject.Fault()
at System.ServiceModel.Channels.ServiceChannel.OnInnerChannelFaulted(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.ServiceModel.Channels.InputQueueChannel1.OnFaulted() at System.ServiceModel.Channels.ServerReliableDuplexSessionChannel.OnFaulted() at System.ServiceModel.Channels.CommunicationObject.Fault() at System.ServiceModel.Channels.CommunicationObject.Fault(Exception exception) at System.ServiceModel.Channels.ChannelReliableSession.OnLocalFault(Exception e, Message faultMessage, RequestContext context) at System.ServiceModel.Channels.ReliableChannelBinder1.Fault(Exception e)
at System.ServiceModel.Channels.ReliableChannelBinder`1.ChannelSynchronizer.OnChannelFaulted(Object sender, EventArgs e)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.OnFaulted()
at System.ServiceModel.Channels.TransportDuplexSessionChannel.SendAsyncResult.Cleanup(Boolean success, Boolean lockTaken)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.SendAsyncResult.OnEnterComplete(Object state, Exception asyncException)
at System.Runtime.AsyncWaitHandle.AsyncWaiter.Invoke()
at System.Runtime.ActionItem.CallbackHelper.InvokeWithoutContext(Object state)
at System.Runtime.IOThreadScheduler.ScheduledOverlapped.IOCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Runtime.Fx.IOCompletionThunk.UnhandledExceptionFrame(UInt32 error, UInt32 bytesRead, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Source: System.ServiceModel
HResult: -2146233087
Type: System.ArgumentOutOfRangeException
Message:
Time-out interval must be less than 2^32-2.
Parameter name: dueTm
ParamName: dueTm
StackTrace:
at System.Threading.Timer..ctor(TimerCallback callback, Object state, TimeSpan dueTime, TimeSpan period)
at Microsoft.Dynamics.Nav.Service.Connection.SetAsOrphan()
Source: mscorlib
HResult: -2146233086
Event Xml:
schemas.microsoft.com/.../event">](http://schemas.microsoft.com/win/2004/08/events/event)
216
2
13
0x80000000000000
10064
Application
User:
StackTrace:
Message:
ParamName: dueTm
StackTrace:
Source: mscorlib
