I want separator after three decimal in my report,
for e.g my amount is 4,00,000. (4 lakhs ).
i want 400,000 (400 hundred thousand )
and same in amount in words.
What version of NAV/BC are you running?
if you are running RDLC, then this is a setting on your field in the report.
i’m using nav 2013 r2 report builder 3.0
Right click your field, and go to textbox property and change the number format
it is only reflecting the symbol
you need to clarify what you mean.
What do you exactly need?
You might need to look at Check report to get amount in words
yes i have checked it but the issue is only with the separator i want it after three decimals as shown in above example
In my amount i want the separator(,) after three decimal like 400,000 by default it is showing 4,00,000
in the screen shot by Lars select number and not currency and try
are you showing just number or is it currency amount?
the amount is in usd
strange make sure you are selecting right currency and format
what happens when you format it as number and not as currency ? where the separator is placed?
it shows like this, but i want it to print 400,7.52
I knew this was the issue. your amount is 40 thousand and not 400 thousand
output is correct what i can see
what you are trying to achieve 400,7.52 is wrong and doesnt make sense
but the if the amount is this
Sorry, but I’m not clear to understand the issue.
If you want to change the view only, you can do the simple procedure - convert the decimal part to the text first (to receive .52 by ROUND to integer) and then select Text for “Integer part” and insert “,” after every 3 symbols starting from End (use DOWNTO).
Something like:
SourceText := Format(Number)
DecText := FORMAT(Number-ROUND(Number));
find a position for “.52” in the source Text
Convert SourceText in the loop with INSSTR
