send unique records from one container to another container
hi,
Actually i have two containers con1 & con2. container con1 having duplicate records.i need to send the unique records from con1 to con2.how can i send these records.
Please any one help me
Hiii Kola,
use this method in job …i think its very good example to understand easily…
static void Contaner(Args _args)
container c1 = [1,2,2,3,4,5,6,6,7,7,8];
container c2;
Set set = new set(Types::Integer);
SetEnumerator se;
int i;
// Load the containre into the set
for (i=1; i<=conlen(c1); i++)
set.add(conpeek(c1, i));
// Get the enumerator for traversal
se = set.getEnumerator();
// Unload the set back into the c2 container
while (se.moveNext())
c2 += se.current();
// Output the container
info(strfmt("%1", con2str(c2)));
Thank & Regards
Nitesh Gangrade
Thank you very much nitesh.it is working
U can do like this…
static void Container2container(Args _args)
container c = [1,2,3,4,1,5,2,6];
int i;
int j;
int l, m;
container c1;
int p = 0;
//info(conpeek(c,1));
c1 = connull();
for(i=1; i <= conlen(c); i++)
l = conpeek(c,i);
for(j = 1; j <= conlen(c); j++)
if(i != j || i == conlen(c))
if(i != j)
m = conpeek(c,j);
if(m != l)
if(j == conlen(c))
p++;
conins(c,p,l);
info(strfmt(“At %1 Position Value is %2”,p,l));
break;
else
continue;
else
break;
else
continue;
