Hi, Any body can suggest how to send a report through email from AOS server rather than from client PC? ie,the report should be sent from AOS server Outlook rather than from client PC? Thanks Preeti
Hi Preeti AFAIK, you have to have open client to run batch jobs. You have got two options here - 1. Schedule to open client, execute the batch and once that is done shut it down safely. 2. Or try to use some tool/application which would enable you to run the batch client as ‘NT service’. If you decide to go this route, you might want to check this component - ServiceMill(http://www.activeplus.com/us/products/smill/) HTH Harish Mohanbabu
