dear sir/madam
In automatic send email Ax 2009 I have this type Errors Please give me solution
Method ‘send’ in COM object of class ‘CDO.Message’ returned error code 0x80040213 () which means: The transport failed to connect to the server.
this is errors
thanks®ards
aliimran
have you set up the e-mail parameters properly.
Administration>setup>system>e-mail parameters
yes but server not connect and error show method SEND and class COM
Are you writing any custom code to trigger the e-mail for any specific activity? If so, First I suggest you to check whether the standard functionality of sending e-mails work.
If the port, account and password not configured properly, obviously it cant connect to the server. Check with your admin on credentials.
under Administration>periodic or Basic>periodic you will find “E-mail broad cast” form. It sends the e-mail to all the online users when you trigger it.( you would need to create a e-mail template to user it). Make sure there are some users connected online and e-mail is mentioned in their user options.
These All Process I done that After all that error show
please send me OK Button Trigger code only method errors Show
all of working right please…And am i create all user email Accounts or not If yes so Tell me Steps
of Create User email Account in ax 2009
thanks & regards
The exact problem is regarding your set up of Email parameters.
May be user name , Outgoing Email server or password must be incorrect.
dear lalit sir
i am using stage server not live server so that Error occurred…
thanks & regards
ali
Hi ali,
Even I’m also facing the same error message while running on stage server (Virtual Server Oracle Virtual Machine).
