When i run the Adjust cost i tem Entries batch job, system throws the error select the dimension value code.
why it is throwing this error.
Thanks in advance.
Thanks in advance.
You have set up the Dim in question as Mandatory, but some entries do not have it.
Examine the message carefully - so you can find out where you need to temporarily switch Mandatory off - otherwise you will not be able to complete the BatchJob.
Check your Dim setups - somewhere you must add Mandatory to avoid such errors further on.Seemingly GL Acc has this setting, but somewhere in Journals/Docs it is not requested.
