There is a simple select statement in AX 2009 inside a find method of MarkupTrans table, it always working fine except for some records even though the data exists inside that MarkupTrans table.
Thru SQL statement I am able to see the data,
Using a X++ job if I call that method by passing the same parameters its giving me the data.
I wonder if any one had the same issue with a simple select statement inside the DAX not returning any data even though the data exists.
Find method :
static MarkupTrans findFreightRec(MarkupTransRefTableId vMarkupTransRefTableId,
MarkupTransRefRecId vMarkupTransRefRecId,
Noyes vfreightFlag = NoYes::Yes,
boolean update = false)
MarkupTrans markupTrans;
markupTrans.selectForUpdate(update);
if (vMarkupTransRefTableId && vMarkupTransRefRecId)
select firstonly markupTrans
index hint TableRecIdIdx
where markupTrans.TransTableId == vMarkupTransRefTableId
&& markupTrans.TransRecId == vMarkupTransRefRecId
&& markuptrans.SLlineNum == 1
&& markupTrans.FreightFlag == vfreightFlag;
return markupTrans;
Thanks in advance.
First of all, make sure that you’re looking into the same company.
If it’s correct, please give as X++ select statement with concrete values (because your code above doesn’t show them) and your SQL code, so we can compare them.
Hi Martin,
Thanks for your quick reply,
X++ Job I am using to call the same method and it worked (but the same not working from that find method don’t know why)
static void Job103(Args _args)
MarkupTrans tMarkupTrans;
TableId tableId = 366;
RecId refREcId = 5641609509;
info(int642str(freightCalculation::findFreightRec(366,5641609509,NoYes::Yes,true).RecId));
select forupdate firstonly tMarkupTrans
where tMarkupTrans.TransTableId == tableId
&& tMarkupTrans.TransRecId == refRecId
&& tMarkupTrans.SLlineNum == 1
&& tMarkupTrans.FreightFlag == NoYes::Yes;
info(int642str(tMarkupTrans.RecId));
SQL Statement :
select transrecid,recid,VALUE,FREIGHTFLAG,SLlineNum, * from MarkupTrans mt where
mt.dataareaid = ‘151’
and mt.transtableid = 366
and mt.TRANSRECID = 5641609509
and mt.FREIGHTFLAG = 1
and mt.SLLINENUM = 1
Just an additional info :
I tried flush all the data and AOD, Usage data and restarted AOS too but no luck.
I did not tried clearing sql cache.
I’m sorry, but it doesn’t make sense. If the code and the context was the same, it would have to work the same. I can only assume that there is a problem not shown in the code above or the problem is somewhere in debugging.
If I got stuck in this situation, I would log queries directly in SQL Server, to see how the actual query differs from the expected query.
Can you please tell me how to log queris directly in SQL.
