jalalm
1
hi all,
i have a field, time in my table that save times,
07:00:00 am
08:00:00 am
01:36:02 pm
12:00:00 am
01:42:36 pm
11:43:20 pm
Now i want to get range between this records, for example between 07:00:00 and 09:00:00 in select statement
how can i to this?
Just use > and < operators in the WHERE clause.
If the type is time, not utcDateTime, note that its saved as the number of seconds since midnight, therefore 7 am = 76060.
jalalm
3
hi martin
thanks for help, but i wrote this code in the button , this not work probably :
select * from InventQuarantineOrder where
InventQuarantineOrder.My_Time > TimeEdit1.value() && InventQuarantineOrder.My_Time<= TimeEdit2.value();
how to change My_Time to UtcDateTime?
Using the time of day alone is not enough - you have to specify a date, such as the current date.
Use DateTimeUtil class for that, e.g. DateTimeUtil::newDateTime(systemDateGet(), TimeEdit1.value(), DateTimeUtil::getUserPreferredTimeZone()).
