save xml file in table
hi,
i 'm looking for to save contain of xml file in a field of table
can you help me
XML is just a text, so a sufficiently long string field will do the job. It usually means that you’ll use string length Memo.
is there a function in standard to save this file in this field of sizestring memo of table
No, use the = operator to assign a value to a table field.
What is really your problem? How to read a file? How to create a table field? Or what?
there is the flux :
in a Accounts payable/Journals/payements/payment journal when i select a payment journal i click on the menu line
a form open ,i select function then generation payment : i have a dailog
when i click in ok AX generate a report and a file.xml . Ther i want to recupere this file and save it in the column of a table
thank you for help
Again: what exactly do you need help with? If you’re looking for somebody to do the whole development for you without any effort from your side, keep looking.
