I have a code which sends a report to each Customer and inserts the date of the last e-mail into a field in the Customer table.
The problem is that there are some cases where errors appear in the middle of the process and the transaction is rolled back(Unfortunately i can’t filter them all out).
Let’s take an example:
I select 1000 Customers and try to send the report and mark the field “Last date”
When at Customer nr 516 I have a error then for no Customer the “Last date” field is saved because the whole transaction is rolled back.
How to prevent this?
I tried to figure it out by myself but couldn’t find a way.
Customer.RESET
Customer.SETRANGE("No.","No.");
IF Customer.FINDFIRST THEN REPEAT
///Here is the part with the report creation and sending on mail\\
Customer."Last date" := TODAY;
Customer.MODIFY(TRUE);
UNTIL Customer.NEXT = 0;
You can split the code into two functions. First Function to Send Email and Second Function to Update the Customer table once first function runs successfully.
Create a function for example with name ModifyFunction and just put it into the code?
Customer.RESET
ModifyFunction();
Although I generally tell people not to use commit, then this is actually a situation where it should be used.
Customer.RESET
IF Customer.FINDFIRST(TRUE,FALSE) THEN
REPEAT
COMMIT;
The reason why COMMIT is dangerous is if you put it into the “wrong” place, then you get transactions committed, which should have “rolled back” on failure. In your case you do the COMMIT after you “transaction” (printing the report), so you’re pretty safe.
PS: Also notice another difference: FINDSET(TRUE,FALSE) as supposed to just FINDSET. Since you are modifying the customer, then you should say that in the command.
