How do you run a report to be able to compare your forecast sales was vs what you had in actual sales in pc counts not in dollar value?
Sales and Marketing - Reports - Sales vs Target
This is where the target is configured in the periodic section of Sales and Marketing.
To do this from the item forecast the idea would be to push the sales forecast to the ledger as a budget and then report financially using management reporter on actual to budget.
Let me re-phrase my question. I need to see the quantity (how many pcs per item) sold not the value. In the current MRP system I use to plan orders to replenish I can see what we sold vs what was forecasted on an inventory level.
Sorry was not in the system so could not check, the target is value only, the forecast however can be unit based, no idea what it does with any quantity transfer, but if you have the forecast in AX you could point SSRS at it and report on it, depends in essence on the structure of your report, i.e. item by forecast and actual.
