In the Sales Tax Groups form we have “OVERVIEW” , “GENERAL” , “SETUP” Tabs
Where i can found the relation between “Overview” & “Setup” tabs
Eg:- When i choose CA in Overivew The Setup Tab show only 3 records
CALA in Overview The Setup Tab showing 6 Records
I am thinking all the changes will effect due to the Enum
Where i can found the Relation ?
kranthi
January 17, 2011, 12:20pm
2
This is because of your tax definition that means your tax configuration - for a tax group you can have different number of tax codes.
Which Enum you are taking about and what exactly you are trying to understand…
It uses tables - TaxGroupHeading for tax groups and TaxGroupData for tax codes…
Hi Kranti,
Here what i want to know is
Eg:- In the Tax Item Group Form
When i choose the SPB in Overivew tab → How setup shows only those related data
where can i found the code ?
In the same way in Purchease oreders Line we have “setup” tab
In that if i selected SPB in Item sales tax group. How it will know which percentage to take bcz it is having so many percentages in setup
As i have mentioned this is because of the relation between the two tables.
Although there are so many percentages - they are defined per tax codes and effective dates.
for that you need to understand how the tax structures got designed.
Here i got something…
When we choose setup tab in the “Item sales tax group” it shows only related fields because of Method “TaxName”
It assigned in the “Item sales tax group form” design → setup → Taxname field → prop is “Data Method”
Here the method “Taxname” is assigned.
But i didn’t get when i choose the SPB in purchease order form line–> setup
How it will take a value from a list. Where i can found the code for fetching a particular value & how can i assign another value from a list of values?
when i choose the SPB how it knows which value to take ?
bcz it is having a list of values ?
kranthi
January 19, 2011, 10:11am
7
What is your requirement?
Hi Kranti,
Here what i want to know is when i select SPB by default it takes the sales code SP_CAST
Why it is taking only that value…?
In table the SPB having a list of TaxCodes…
