I am trying to post a delivery note for a sales return order and I get the error message “Replacement Order Setup is missing”. Where do I need to amend the setup?
I am using the following process:-
- Create a return order for an item
- Create a new arrival journal.
- I am using the default values to select the return order RMA number, I am unticking check the picking location and then using the Functions button to create the lines.
- I enter a disposition code of Replace and the location to replace into.
- If I post the arrival journal I get the return sales order OK but when I try to post the delivery note I get the error stating that I am missing the replacement order setup.
What other fields do I need to complete to create the replacement order?
