I have generated a Sales Quote in AX 2009 version. But after processing the step “Quotation” the option “Confirmation” is not enabled.
Is there any more settings to activate this option button?
Thanks.
Thanks.
You have probably raised a quote against a business relation. unless AX knows the customer it will not let you confirm it (generates a sales order). I suggest if you go to the BR record and run the function to convert it into a customer the confirmation option will then become available.
Thank you very much for your reply.
It helps me to come out of this issue.
It works.
Thanks again.
Ashlesh
