Hi!
Can anybody help me on how to post a sales/purchase invoice with zero value. These are usually for “sample Items”.
Im trying to post but message is saying that cant leave the Line amount Zero.
Tina
Hi!
Tina
Hi!
According 2 me you should go to Sales & Marketing->sales order.
in sales order document.,in the header portion apply a check on free supply check box
and in sales/purchase invoice select the item and dnt change the actual value.
when you will apply the check it will automatically take zero value in linei.e line discont %age will be 100%
this can be done for sample items or any other free supply
try it and then let us know is it working?
Witch version are you using? I have posted a sales invoice without any value and I didn’t had any problem.
I remember a client once that had a similar issue. They needed to send samples and couldn’t because of this message. Of course when I hunted it down, I found that they told their partner to make a mod to prevent the sale of items with less than a certain markup (something like 10% hard coded in table 37). The partner had merrily just written the code as requested.
Issues like this were behind my rather contoversial blog
Its definitely a modification, as already David wrote.
In standard NAV you can post SO both with zero price or 100% Line Discount - only G/L Accounts involved change in these two situations.
and this is a mod, too - or Indian localization.
HI !
But i cant see any “FREE SUPPLY” on the header part?
Tina
Hi! Nuno…Im using W1 5.0
Hi
As Modris said earlier in the post, this is either an IN localised field - so you have to be running it, or it is a modification.
You have a modification in your system, so I would recommend you speak to your partner about it as they would have, probably, implemented it.
hi Mr. Adam,
Thanks. I will ask our IT guy to do it.
