A sales invoice posted, after few days this invoice was reversed and again the reversed invoice was reversed. but the actual invoice is not showing in GL.
Eg Invoice EI-0012 was posted on 29/04/2013 then this invoice was reversed 15/01/2014 i.e RL13-SR-0066 and again RL13-SR-0066 was reversed on same day 1/01/2014 EI-0167. Both the invoice are showing in GL RL13-SR-0066 and EI-0167 but EI-0012 is not showing in GL of 29/04/2013.
Define the process of “reverse” in this scenario please.
I suggest you analyse the vouchers and posting dates to see the final situation and look at the posted invoices to do this from to analyse the voucher transactions.
Reverse means i have created credit notes and posted it. I had checked all the vochures posted, it shows in sales register but are missing from GL transactions
I have invoice on 24/04/2013 and credit note on 15/01/2014, credit note can be seen in 15jan’s GL but previous invoice is not present in GL i.e of 24/04/2013
I have posted invoice on 24/04/2013 and credit note on 15/01/2014, credit note can be seen in 15jan’s GL but previous invoice is not present in GL i.e of 24/04/2013
Ignore the dates - look at the invoice and the financial transactions - then you will see where it is in the ledger - unless you sold it at zero.
Also there are a number of ways of raising a credit - manual entry on the line, credit note process in the order, return order… I am presuming your reference relates to the credit note function within the order.
