I have created the sales order in which one item is delivered partial and now when i am cancelling the delivery reminder for that item showing the following error:
“Quantity ordered may not be reduced because there are not enough inventory transactions with ‘on order’ status.”
Probably you are cancelling the delivery reminder for the line item whose quantity is already picked through picking list registration, so try unpicking those quantity and give a try.
Im facing the same issue right now. I have tried all the methods given above, but its not working. As the last suggestion to ‘End Inventory Order’, when I go to Output order form / Function and found the ‘End Inventory Order’ is greyed out.
how can I delete this transaction on order? please help.Tq
@varma, I tried ur method, it worked by adding to the physical inventory, but the available quantity being derived by deducting the ordered from the physical inventory. So how can u unpick such that it doesnt change the status to "on order " again.
