While Posting Sales Invoice i’m getting inconsistency error. I am using Indian Version Nav client. In 5.0 SP1 and 2009 SP1 verion same error while posting Sales Invoice.
Select any customer with USD currency
In Sales line select G/L account and fill other details.
In 3rd line select type as " " and fill only description
When i try to post it is throwing inconsistency error. If i create another empty line posting is sucessfull. If empty line is 2,4,6,8… it is posting and if it is 1,3,5… then only it is throwing inconsistency error
Thank you for the quick reply. I have attached Sales Invoice details. This customer is having USD currency. If i try to post this particular invoice alone im getting an inconsistency error. Dont forget to create an empty line with description alone and try to post it. This i have checked in base Nav DB there is not customization in tat DB.
You will need to get your partner to look at the modifications made to your system, as it would look, on the face of it, as if a modification is causing the error.
