sALES fORCE iNTEGRATION TO bc 365 oN pREM bLUEPRINTING
I have been tasked with a Sales Force to BC 365 integration project. The requirements are not taht complex. There is no Data writing. Only 8 sales people being able to see their active sales orders , their status , and inventory levels of the items in their sales orders. II have to mention we are have on prem edition. We have been approached be a myriad of BC and SF consultants each offering their approach to the task ranging from full development utilizing java coding and batching data modifications (they did not understand - no edits) to utilizing SmartConnect - which is the architecture I support but is far too costly for the licensing. I have blue printed a solution utiolizing azure as the “middleware” and would like to get some feedback on this. The following is a snippett from the paper I presented to the stake holders. Can anyone tell me if they have had experience with BC to SF integration and if my thoutghts are a valid approach to this?
While conceptually SmartConnect was a viable choice to implement the architectural requirements of our company, it is not the recommended middleware selection that we feel allows us to reach our goals in a cost effective timely manner.
These above mentioned enitities (Sales orders, inventory etc) will be synchronized using Azure Logic Apps (Consumption Plan) with a Microsoft-supported On-Premises Data Gateway, replacing custom Apex logic with a configuration-driven, low-code model providing built-in retry, logging, and monitoring.
That way the Azure Apps model will provide real-time Operational Data Access, and not have us reliant on batchihng .
Our salesd people require real-time access for our Sales Force personnel to include:
· Inventory availability
· Customer-specific pricing
· Order status (holds, releases, shipments)
· Accurate quoting
· Accurate availability
· Live fulfillment visibility
I di inot want to get into the weeeds but merely gain insight into whether this is a viable, best practice solution .
Hi @Dale_Jones
Your Azure Logic Apps approach is the right call - real-time data, configuration-driven, no batch delays, exactly what your salespeople need.
Why it works:
Logic Apps + On-Prem Gateway is built for this. Microsoft-backed, cost-effective, and you own the architecture.
Why others fall short:
  • Custom Java + batching → Stale data, high maintenance
  • SmartConnect → Enterprise overkill for read-only access to 8 users
Since we started with BC, this is exactly what we’ve been helping clients do. Keep it simple, keep it real-time.
One tip: solid monitoring from day one (Logic Apps logging handles this well).
Happy to discuss specifics - data model, sync frequency, gateway setup. Feel free to reach out.
I would love to send you what I have composed for my company in direct opposition to a customized batching (stale data) java app. A company out of India was wanting Approximately 45K to basically give me a beta version with a mndatory 50 support clause - meaning an additional 12K And no set timeline. To reduce “Vendor-locck” and billable hours for java customization, I changed architecture and started to look at SmartConnect. Unbelievable licensing cost - about 21k a year , but a reduction in dev time billings. So I looked further and since we have the Azure licenses an we have on prem (my specialty is SQL server) I actually am now looking at a 19K turnkey for time and materials. I am a past full-time Micrososft Corporation employee and and reached out to a few of my past colleagues and they told me the architecture is solid and I broke down the “persession” costs and I do not think we will exceed 35 dollars a month. I have 6 sales people who just need to see sales info but have no BC on their systems. Anything you can show me or give me would be so welcomed. I am a Sr. Systems Analyst and any sucesses I have is directly attributed to including people smarter than me into my plans LOL If our IT departrment had evrything in order from our end - how many hours do you think it would take to implement datasets that should only include sales info and customer info and maybe inventory - and also the page/form views in Salesforce - roughly.
Hi @Dale_Jones
You nailed this. Logic Apps + On-Prem Gateway beats Java batching and SmartConnect’s licensing overhead every time for read-only access. Your $19K estimate is realistic.
Quick timeline (IT prerequisites handled):
  • BC OData/REST endpoint setup + Logic Apps connectors: 35-50 hours
  • Salesforce Lightning component config (display sales orders, inventory): 25-40 hours
  • Testing & monitoring: 15-20 hours
Total: 75-110 hours
One practical addition worth considering:
Build a simple BC REST API (using AL, takes 2–3 days) that wraps your sales order + inventory queries. Here’s the real benefit:
  • You control what SF sees, expose only the fields your 8 reps need, not raw BC tables
  • BC OData filtering is clunky for complex queries (customer-specific pricing, hold logic), your API handles it cleanly
  • Easier debugging, one endpoint vs. multiple Logic App flows
  • Your SQL expertise applies directly; this is just AL-wrapped queries sitting on BC
Logic Apps then calls your API instead of wrestling with OData filters. Cleaner, faster, maintainable.
Real questions for your setup:
  1. Are you using BC OData or direct SQL queries via the gateway?
  2. Service account auth, or managed identity?
  3. Do your sales reps need live data, or is 10–15 min acceptable?
This is a straightforward play. Happy to walk through the API architecture or Logic Apps specifics if you hit friction.
You’re delivering solid value here.
EMAIL HERE
